1997 Pontiac Sunfire Cylinder 3 Misfire
BMADER06
I was just wondering what my next step should be on the repair of this car. I've replaced the plugs, wires, O2 sensor, the injetors are pretty new, the coil pack with ignition module have been replaced, and the fuel filter w/ 3 bottles of lucus injector cleaner put into the gas tank. The car seems ok under hard acceleration, but the idle and slow acceleration are still very hesitant. Any info would be insightful.
b
Aug 24, 2006 at 9:19 PM
MIKEYBDMAN
  • 623 POSTS
[quote:1c129a511b="bmader06"]I was just wondering what my next step should be on the repair of this car. I've replaced the plugs, wires, O2 sensor, the injetors are pretty new, the coil pack with ignition module have been replaced, and the fuel filter w/ 3 bottles of lucus injector cleaner put into the gas tank. The car seems ok under hard acceleration, but the idle and slow acceleration are still very hesitant. Any info would be insightful.
b[/quote:1c129a511b]
Might be a good idea to check the compression of all of your cylinders. See if that one is low, and fix the cause. If not that, you might want to remove the crankshaft sensor and inspect the reluctor wheel for any defections.
I would have the no.3 injector tested, or even replace it with one of the other cylinders.
Aug 27, 2006 at 10:51 AM
BMADER06
Thanks for the start....
Aug 27, 2006 at 11:45 PM
Suggested Repair
Check compression on all cylinders and repair the cause if cylinder 3 is low. If compression is fine, inspect the crankshaft reluctor wheel for defects and test or swap the number 3 injector with another cylinder.
Conversation Summary
The owner of a 1997 Pontiac Sunfire 2.2L with a P0303 cylinder 3 misfire has already replaced the plugs, wires, oxygen sensor, coil pack and ignition module, and fuel filter, and has used injector cleaner. The car runs better under hard acceleration but remains hesitant at idle and during slow acceleration. The expert recommends a compression test, inspection of the crankshaft reluctor wheel, and testing or swapping the number 3 injector.
