Electrical problem
1996 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
Headlights were just working on it checked fuses all ok but checked for power to bulb with tester but showed no power
Sunday, May 9th, 2010 AT 6:52 PM
INTERNETMECHANIC
MECHANIC
Did you use a voltage tester on the fuse circuit? Even if the fuse is good, if no voltage on the circuit, the circuit is dead. Check voltage circuit for both headlamps. In the diagram, the top wires at both lamp assemblies, is voltage. The bottom wires are ground, one ground for low beam, another ground for high beam.
