1991 Pontiac Sunbird 160,000 miles automatic transmission.
RANDR69
  • 1991 PONTIAC SUNBIRD
My car has a very slow acceleration problem. You could step on the gas and it doesn't go until you stomp on the gas. Then it goes very slow and almost dies. It takes it about 20 to 30 seconds to accelerate, and then if you let off the gas the acceleration starts to get normal
Sunday, June 24th, 2007 AT 10:25 PM
RANDR69
I asked this question the other day, but there is a little more to it now. The car sat for about a year due to a timing belt issue. I have changed the timing belt. Since then I have slowly had more and more trouble with the way it runs. The acceleration is slow-it takes it forever to go from a complete stop and is now trying to stall out. It backfires sometimes and it at times seems it's not getting any gas. I'm trying a tune up and oil change done tomorrow. Aside from that what else can I do to improve the way it's running? There is also a whine that sounds like it's coming from the transmission when i'm stepping on the gas, and it's slow to go. Once it shifts gears it goes fine. Also it seems to do better once I get it past 40 before 40 it runs really bad.
Wednesday, June 27th, 2007 AT 8:34 PM
SC1 RACING
  • 117 POSTS
Are the engine rpms raising and car not moving or is it just sluggish? Could be a tooth of on timming belt/chain. Could be stopped up converter.
Wednesday, June 27th, 2007 AT 10:18 PM
RANDR69
Just sluggish. It feels almost at times like it's not getting any gas, but at the same time it could go two city blocks before I can get it past 20-25. It's rather annoying.
Thursday, June 28th, 2007 AT 12:41 AM
SC1 RACING
  • 117 POSTS
Have you replaced fuel filter?
Thursday, June 28th, 2007 AT 1:00 AM
RANDR69
No, I haven't gotten that far yet, how many are there and where are they
Thursday, June 28th, 2007 AT 6:53 PM
LADYMACHIAKAREE
I bought a Sunbird yesterday and it is doing the same thing, aside from that mine, needs about 1-2 quarts of transmission fluid per-day. I am not sure as to why it is doing this, I am definitly going to try replacing all the puel filters tomorrow though. If you have found out how to make yours go like it is supposed to, you should write it on here and let me know what else to try!
Thanks in advance!
Lady Machia Karee
Monday, August 20th, 2007 AT 1:20 AM
