1993 Pontiac Grand Prix Water Leak
PONTIAC
TIGGSGGRRR
I have a pontiac grand Prix se 1993 Recently it started leaking and spitting water from the belts. I changed the water pump but it still spits and leaks a little. Dont know what it is. Please help, ty :( :cry:I am a ladie and dont know much but will appreciate the help, even if i have to take it to a mechanic. Trying to do this on my own.
Dec 20, 2006 at 11:10 AM
BOOTDOG
  • 665 POSTS
ok, what you need to do is have the radiator pressure tested. this will determine where the leak is comming from and then you can have the repairs done. any auto repair shop you take it to can do this test. or if you know someone who can do this to help you save money, will work also. just be careful, there are some honest mechanics out there and there are those who like to take advantage on people. have them show you exactly where its leaking from. hope this helps and good luck :D
Dec 20, 2006 at 12:36 PM
82TA
it could also be an intake manifold leak
Dec 20, 2006 at 2:29 PM
Suggested Repair
Have the radiator and cooling system pressure tested to locate the leak, and have the shop show the exact source before repairs. Also check for an intake manifold leak.
Conversation Summary
The owner of a 1993 Pontiac Grand Prix SE reports water leaking and spraying from the belts after replacing the water pump. An expert recommends a radiator pressure test to pinpoint the leak and having the shop show the source. Another reply suggests it could be an intake manifold leak.
