2003 Pontiac Vibe Spark Plug Change
PONTIAC
BOB CUNNINGHAM
How do you change the spark plugs on a 2003 Pontiac Vibe, I can't find them.
Jul 18, 2007 at 8:28 AM
MMPRINCE3000
  • 133 POSTS
You have to remove the black cover. Then the individual coils for each plug. These plugs are Denso or NGK iridium and are supposed to last 100,000 miles.
Replace them with Denso or NGK iridium and put a dab of anti-sieze on each plug thread.
Do this when engine is COLD.
Aug 6, 2007 at 10:55 PM
Suggested Repair
With the engine cold, remove the black cover and the individual coil for each plug. Replace the plugs with Denso or NGK iridium plugs and apply a dab of anti-seize to each plug thread.
Conversation Summary
The owner of a 2003 Pontiac Vibe could not locate the spark plugs and asked how to change them. The expert explained that the plugs are under the black cover and individual coils, recommended Denso or NGK iridium replacements with anti-seize on the threads, and advised doing the work only when the engine is cold.
