I can't find in the Chiltons Mechanical Manual on what must be removed to change my spark plugs and wires.
Mar 12, 2006 at 7:19 AM
Remove the decorative cover marked 2.4L Quad by taking out the four bolts at the upper left, upper right, lower left, and lower right. Lift and rock the cover so the boots release from the plugs. The plugs are at the bottom of the V-shaped opening. This engine uses spark plug boots rather than spark plug wires.
The owner of a 2001 Pontiac Grand Am 2.4L asked what must be removed to change the spark plugs and wires, noting the Chilton manual did not explain access. The expert said to remove the four bolts on the decorative 2.4L Quad cover, lift and rock it so the boots release, and reach the plugs at the bottom. The engine uses spark plug boots, not wires.
