1992 Pontiac Grand Am No Spark
1992 ALL OTHER MAKES ALL OTHER MODELS
VANMAN42
  • 23 POSTS
I have a 92 grand am,2.3 sohc quad4,it sat for for a couple of years. I decide to put it back on the road,now it won't start. fuel pump and injectors are fine, seems to be no spark,replaced crank position sensor,it getting power to the 11 pin con. but dosen't seem to be getting power to the crank position sensor plug. I supect the module is bad how do I test it?
Jun 2, 2006 at 9:06 AM
LOSONE
  • 1,616 POSTS
It probably is the ignition module. Take it off and most parts houses have a way to test it. good luck
Jun 2, 2006 at 10:39 AM
VANMAN42
  • 23 POSTS
I took it to autozone they didn't have the hookup to test it,thats the only place I know of to test modules. It's $95 to replace it so i'd like to know if it was bad first.
Jun 2, 2006 at 11:27 AM
LOSONE
  • 1,616 POSTS
Take it to a NAPA store. They have a way to test it. I by nothing from the Zone except if i can pour it out of a bottle. They sell very poor parts but you get what you pay for. Good luck
Jun 3, 2006 at 12:14 AM
Suggested Repair
Have the ignition module removed and tested at a NAPA store, which can test modules that Autozone could not. Replace the module if the test shows it is bad.
Conversation Summary
The owner of a 1992 Pontiac Grand Am 2.3 Quad 4 that sat for years reports no spark. The fuel pump and injectors are fine, the crank position sensor was replaced, and power reaches the 11-pin connector but not the crank sensor plug. The expert suspects the ignition module and recommends having it tested at NAPA after Autozone could not test it.
