2000 Pontiac No Start After Out of Gas
Might have clogged the fuel filter or burned out the pump. Change the filter if it has not been done recently. When you first turn the key to the on position the pump should run for a second or two. Listen for it even if you have to open the fuel cap and listen while someone else turns on the key.
If you can't hear anything check the fuses first.
Good luck and let us know.
Clean the connection off first, especially if it was undercoated. Spay a little lube (WD-40, etc.) into the connection first. Push the tool into the little tabs and yank the connection apart.
Your welcome I guess. What was the problem?
Suggested Repair
Replace the fuel filter if it has not been changed recently, confirm the fuel pump runs briefly with the key on, and cycle the ignition on and off several times to build fuel pressure. If the pump runs but no fuel reaches the rail, check fuses and inspect for a pinched fuel line.
Conversation Summary
A 2000 Pontiac would not start after running out of gas. The expert suggested a clogged fuel filter or failed pump, advised listening for the pump with the key on, and checking fuses. After help disconnecting the filter, the car still had no fuel at the rail. Cycling the ignition to build pressure, along with the filter replacement, got the car running again. The owner attributed the fix to the new fuel filter and priming the line by switching the ignition on and off.
