1982 Pontiac Lifters Collapsing
PONTIAC
GRAMMYBOO
I have a 1982 2.5 liter 4 cylinder Pontiac engine, it was rebuilt at 60,000 miles, it now has 21,000 miles on it. The rocker arms are non-adjustable, they just tighten down with a bolt. If you turn the rocker arm bolt until the rocker arm reaches zero lash how much should the bolt turn until tight? My bolts turn 1 1/2 to almost 2 turns, I am having a problem with lifters collasping.
Jun 28, 2006 at 4:56 PM
HMAC300
  • 48,601 POSTS
there should be a rtorque spec if it's a bolt. It shouldn't turn another one and half to two turns. If it's a nut on a stud then the best way to adjust it is to bring each cylinder up to zero, take all the play out of the pushrod then tighten it down 1 turn. That should do it.
Nov 1, 2009 at 1:15 AM
Suggested Repair
Do not tighten the rocker bolts 1.5 to 2 turns past zero lash. If they are bolts, torque them to the specified value. If they are nuts on studs, bring each cylinder to zero lash, remove all pushrod play, then tighten one turn.
Conversation Summary
The owner of a rebuilt 1982 Pontiac 2.5L four-cylinder with non-adjustable rockers reports collapsing lifters. The rocker bolts turn 1.5 to nearly 2 turns after zero lash. The expert says a bolt should be torqued to specification and should not turn that far; if it is a nut on a stud, remove pushrod play at zero lash and tighten one turn.
