Pontiac Grand Prix Key Stuck and No Power
In both cases, we think of the tumblers as a sure bet that they have gone bad and not allowing the key to turn. Not always true.
Lets do a few basic things that can clear it up. Manual release! Should be on the bottom of the column like the first guy referenced. If you can manually release the key, then your tumblers are not the problem (most likely). So, on to why your key wont come out. In most cars they have a park position switch that supplies a ground to the key unlock solenoid to release the key when you are in park. If the car would run and everything is perfect except the key wont come out, then I would suspect the park position switch as being bad. But, since you have totally lost power, then the solenoid has no power to release the key. Now to the problem at hand. Your ignition switch seems to have gone bad, and not supplying the car with power, which includes the solenoid to remove the key.
Now, I would make sure your battery is not completely dead. I have seen them short internally and just have no power what so ever. That two will fit the symptoms you describe.
Please post back the fixes to both of your problems and maybe I can learn a little also.
Good luck.
Just to add one more detail, my car has the alarm system and there is a red light that is supposed to be on when the car is turned off. But now it is dead too. Also, I just had my driving belt and air in-take changed by a mechanic one day before the car was dead (I did drive the car at that night and has no problem, but it was dead the next morning). I am not sure whether this information is helpful to identify the problem. Thanks a lot![/quote:8bdfc9fc50]
Those red lights are supposed to blink when the ignition switch is off. However, if it is bad, it may not be telling the alram I am off. Its not telling anything to any system. Not saying om off, and not saying im on.
I would take a volt meter, and check your battery to see if it has power. Check the cables and make sure they are clean, tight and free of corrosion. I would also check for power at the start relay. If you find the main power cable to the starter relay, and you place the positive terminal of your meter on that post, and the negative terminal to the case of the starter, or frame, you should read battery volts. The reason I say check it there is to eliminate the battery connections. Power has to flow from the battery to the start relay, thru your meter, thru your frame or case and back to the battery thru its cable for you to read voltage. At this point I would repace the ignition switch.
good luck let me know if it works
rick
jobsearch623@yahoo.com
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Suggested Repair
Check battery voltage and that both battery cables are clean, tight, and free of corrosion; a loose negative cable can cause total power loss and a stuck key. If jump-starting fails and battery voltage is present at the starter relay, replace the ignition switch, which also powers the key-release solenoid. If the car otherwise runs but the key will not release in Park, check the park-position switch.
Conversation Summary
Owners of 1999 and 2000 Pontiac Grand Prix models reported a stuck ignition key, no crank, and a complete loss of electrical power, including the security light. An expert said a dead or internally shorted battery or bad cables should be ruled out first, then the ignition switch if there is no power to the key-release solenoid; the park-position switch is more likely only when the car otherwise has power. A dealer quoted an ignition cylinder, and another owner reported the same symptoms from a loose negative battery terminal. A separate shift-and-key issue was attributed to a failing transmission shift cable.
