1998 Pontiac Trans Sport P0420
PONTIAC
PITAX1
i have a 98 pontiac thansport, it has a p0420 code
i cant figure out what i would look for in the #1 bank
doug
Mar 22, 2007 at 4:56 AM
SERVICE WRITER
  • 9,123 POSTS
It has to do with the converter not being perceived as efiecient enough. Has the converter been replaced ?
Mar 22, 2007 at 11:50 AM
PITAX1
yes about a year ago.
there is only one converter so why wouldnt both banks have a problem
Mar 23, 2007 at 3:54 AM
SERVICE WRITER
  • 9,123 POSTS
If I could give you an intelligent answer on that I would. One possiblitly is a leak on that side that is allowing the exhaust gases to be altered. That will throw this code.
The code you show, suggests that if a converter was replace with one the varies from the original, such as a universal, the code will be thrown for that as well.
Mar 23, 2007 at 10:56 AM
Suggested Repair
Check for an exhaust leak on bank 1 that could alter the exhaust-gas readings, and confirm the replacement catalytic converter matches the original specification rather than a universal unit.
Conversation Summary
The owner of a 1998 Pontiac Trans Sport has a P0420 code and asks what to inspect on bank 1. The converter was replaced about a year earlier, and there is only one converter. The expert explains that P0420 means the converter is not seen as efficient enough, that a leak on that side can alter exhaust gases and set the code, and that a universal converter differing from the original can also cause it.
