1992 bonniville runs 20 to 30 min and wont restart
1992 PONTIAC
WMILLS
Hello i have and 1992 pontiac bonniville SSEI with 92000 on it it runs for 20 to 30 min sometimes it dies if it does not die and you shut it off it will not start for a hour hour and half. I have replaced the fule pump. Plugs,wires,control module,coil packs and the cam sensor. when the car is cold it fires right up and runs great. Thanks
Jul 5, 2006 at 4:50 PM
UNCLE BUCK_2006
had a lumina with the same problem, found a short in the radio, the person put a piece of cardboard in the power button to make work. pulled the fuse and it has been a month and no issue
Jul 25, 2006 at 12:11 PM
