update: I hooked up a scanner to read codes, and there is no power at the DLC connector. Any ideas where to look for a cause like this? Thanks!
Thanks for the reply! I could not locate a bad fuse to the DLC, so decided to use a jumper wire with a 5amp fuse and backprobe the connector to supply 12v. It worked-powered up the scanner, read code (#2 cyl mis-fire). Problem was loose rocker arm. Re-torqued and all is running well so far. I was not able to pinpoint the noise from the stethlescope, but pulling the plug out to see it was fouled verified the cyliner location.
Thursday, July 20th, 2006 AT 9:27 AM
