2000 Pontiac Montana crankshaft pulley
EMPIRE490
Engine Mechanical problem
2000 Pontiac Montana Two Wheel Drive Automatic 147000 miles
My serpitine belt came off.I put on new one and when I started it up the belt came off.I noticed when I went to put belt back on that the crankshaft pulley is not inline with the rest of the pullies alt,aipower steering.What would cause this to happen?
May 12, 2009 at 1:07 PM
KEITHANDBEV
I have just experienced the same thing today...........any ideas anybody
Jan 24, 2012 at 12:27 AM
  • 75,988 POSTS
You crankshaft pulley could be loose try torquing it to specs and inspect the other pulleys double check belt tracking/alignment
Jan 24, 2012 at 1:06 AM
KEITHANDBEV
In another forum I found many Montana's where the Harmonic Balancer has come apart which is causing the pully to be 1/2" out of alignement so I will check this now..........thanks everybody.
Jan 24, 2012 at 1:12 AM
MATTF6
What were the results? I have a similar issue with the same year/make/model.
Thanks for any info.
Aug 16, 2013 at 11:26 AM
DKROESE
I had the same problem and the harmonic balancer (102K miles)had actually started to separate and caused the pulley to move forward. Oriellys to my surprise had it in stock so I suppose it is a common problem. At the same time I found everyone of the idlers/bearings(there are a few) were wore out so I replaced them
Aug 17, 2013 at 4:17 AM
