Serpentine belt on it is not lining up with the harmonic balancer
1,935,430 MILES • 3.4L • 6 CYL • FWD • AUTOMATIC
RICHARD WILFONG
When i put my Serpentine belt on it is not lining up with the harmonic balancer from idilier pulley and when i start the engine the belt jumps off. can you tell me why? thanks, Rick
Jan 27, 2017 at 9:40 AM
CARADIODOC
  • 34,414 POSTS
Can you explain, "not lining up"? Do you mean the belt is too long? Can you see the belt not sitting squarely on a pulley, or it is peeking out to one side when you sight down from on top?
Jan 27, 2017 at 9:53 AM
RICHARD WILFONG
Yes, when i look down on the belt it is toward the engine from the harmonic balancer. thanks
Jan 27, 2017 at 10:03 AM
RICHARD WILFONG
Not straight. thanks
Jan 27, 2017 at 10:04 AM
CARADIODOC
  • 34,414 POSTS
The best I can suggest is to look for any pulley where the belt is not sitting straight on it. That pulley or the one right before it is tipped or turned, usually due to a worn bearing. That mostly affects idler and tensioner pulleys. Also, consider that most pulleys are painted black, and that paint only wears off where the belt was running before. Look for a pulley where the belt is running on a painted area. That will show any pulley where the belt has changed position recently.
Jan 27, 2017 at 10:24 AM
