2003 Pontiac Montana starting
OFFLEAD3
  • 2003 PONTIAC MONTANA
  • 6 CYL
  • 85,000 MILES
When I start 2003 Montana the engine cuts out, doesn't stall, before I can get my fingers off the key, turn the key again and it starts and runs fine. This happens EVERY time, hot or cold. Have plenty of fuel pressure, put injector cleaner in tank, had injecters cleaned at oil change place, turn key on to let pressure build up, then start, still happens.
About every other day the knock sensor code comes up, replaced knock sensor code still comes up about every other day. Battery is original but still says 12.5V.
thanks
PK
Friday, September 11th, 2009 AT 7:31 AM
  • 109,885 POSTS
Is that the only code that has come up? Also, what is the fuel pressure and is fuel pressure drop off within spec?
Wednesday, September 23rd, 2009 AT 1:41 PM
OFFLEAD3
The fuel pressure was one of the first things I checked.
IT was a while ago but I think it was over 45 and only dropped a little when started.
The knock sensor code is still only code that comes up.
Thanks
Wednesday, September 23rd, 2009 AT 2:08 PM
