2001 Pontiac Montana Pontiac Montana Problem
153,000 MILES • 6 CYL • FWD • AUTOMATIC
JOEPETERMAN
I have a 2001 pontiac montana, had usual gasket problems. Head gaskets just replaced along with other items (cost 2400.00).Since then car bucks & jerks on acceleration and sometimes at highway speeds.If you floor it on accelerating its o.k. I have since had the crank position sensors replaced.No good. Had a mech. say to replace computer module ( 800 ) to start but that may not take care of it.Is it possible that timing was put off on re-assembly? Or any suggestions would be appreciated.
Jun 11, 2008 at 8:48 AM
  • 75,988 POSTS
Get the fuel pressure check, the throttle position sensor and the manifold absolute pressure sensor checked out-
Jun 11, 2008 at 9:05 AM
RHALL77
  • 3,361 POSTS
also check for a bad plug wire. they may have damaged one when they performed the head gasket job
Jun 11, 2008 at 9:06 AM
