1999 Pontiac Montana
BAROSJOEY
Engine Cooling problem
1999 Pontiac Montana 6 cyl Front Wheel Drive Automatic
i have changed t stat, t stat housing, sensor on housing and both fan relays. cooling fans still not working is there a temp switch if yes where is it located
Apr 20, 2010 at 9:13 AM
  • 110,248 POSTS
Are you sure the fan motors are good? As far as the switch, the sensor can be found on the right side of the engine.
Here is its purpose:
"The Powertrain control module (PCM) controls the operation of the cooling fans. This is accomplished by providing a ground path for the cooling fan relay coils within the PCM. The relay contacts will close and complete the circuit between the Maxifuse® in the underhood electrical center and the fan motors. Whenever there is a fan "on" request, both fans will be running. A coolant temperature switch activates the fan motors. A transducer can also activate the circuit, depending upon A/C request or A/C compressor head pressure to the condenser."
Let me know what you find.
Apr 24, 2010 at 5:09 PM
