2005 Pontiac GTO How much does cylinder head gasket replace
2005 PONTIAC GTO
45,000 MILES • V8 • 2WD • AUTOMATIC
YEOMANDROID
My cylinder head gasket blew on my 2005 Pontiac GTO and I am being charged about $3000.00 for the repair because GM simply makes terrible cars. I feel that I am being ripped off but seeing as how much work that is involved, I'm not sure. I live in the Los Angeles, CA area so I don't expect labor to be cheap. But still, 3K is a lot of money for me.
Oct 26, 2010 at 9:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If you are having both cylinder head gaskets replaced that should only take approx 11 labor hours. Even at a rate of $100 an hour (which most is around 80) that would only be 1,100 in labor fees and another 100 or so for the new gasket set. I would not see it costing 3k for a head gasket repair. I would suggest having another shop give you a quote.
Oct 26, 2010 at 2:17 PM
YEOMANDROID
They replaced the spark plugs, the valves, thermostat and fluids (oil and coolant) in addition to the transcooler hoses. I would assume this is part of the expense too.
Oct 26, 2010 at 6:04 PM
YEOMANDROID
[quote:5756a04966="YeomanDroid"]They replaced the spark plugs, the valves, thermostat and fluids (oil and coolant) in addition to the transcooler hoses. I would assume this is part of the expense too.[/quote:5756a04966]
Correction, I just learned the valves were machined not replaced as this is not very common to be damaged. I am being given a refund of $371.00 for being charged over heater hose that was damaged during the head removal (why I got charged for it is beyond me). So I assume the price for 8 exhaust valves are around $211.00 for an LS2 V8 engine.
Oct 27, 2010 at 10:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
With all of those additional repairs and parts and with the partial refund I'm going to have to take back my initial statement and see this was indeed a fair cost then..
Oct 28, 2010 at 9:12 AM
