2004 Pontiac GTO EBS warning - starter..?
70,000 MILES • V8 • 2WD • MANUAL
RIFF_11B
My EBS warning came on and i tried to start it, but it wont start, wont even try. it just clicks, could that be the starter, or something electical that has to do with the factory security.[img:1ba099a68d]http://www.2carpros.com/forum/automotive_pictures/502602_super_chaged_1.jpg[/img:1ba099a68d]
Oct 10, 2010 at 7:34 PM
HMAC300
  • 48,601 POSTS
if it clicks it may not be your security system. look on your underhood electrical center and see if you can find the starter relay. that may be bad. It should be marked on the inside of the cover. Try replacing that and see if it does any better. if not clen your battery cables and chare your battery. then have the battery tested, alot of auto parts stores do this for free.
Oct 11, 2010 at 11:31 AM
