1970 Pontiac GTO ignition lock
DRCARNUT
Steering problem
1970 Pontiac GTO Two Wheel Drive Automatic 58,000 miles
How do I R & R the ignition lock on my 1970 GTO (A Body)
I have already removed the steering wheel
Thanks
Jan 26, 2010 at 11:01 AM
HMAC300
  • 48,601 POSTS
once you get teh lock plate off and can see the ignition swirtch lock, put teh key in and turn it and push the button where the lock goes in and pull the lock out. to install just put the lock back in and turn towards start afterall the way in then take the key out and you reassemble everything.
Feb 2, 2010 at 1:23 AM
