White smoke out exhaust is either the headgasket or intake gasket, and needs to be repaired ASAP, as it will damage O2 sensor and convertor, and if leaking bad enough can cause the engine to hydrolock, where cooland leaks into combustion chamber and bends a rod or breaks a piston.
I would have a trusted mechanic diagnose it, first with compression test, then cooling system pressure test.
Tuesday, September 3rd, 2019 AT 2:29 PM
(Merged)
