Hello -
My water pump failed in February and I had it replaced. I also had my transmission rebuilt in May (torque converter). Prior to having the transmission revuilt, the transmission fluid temp was consistently running high (200+ degrees). Almost immediately after having the transmission rebuilt, I was out of the country and my wife drove the car while I was gone.
After returning, I noticed that my engine temperature would run hot fairly quickly (consistently into the last hash mark prior to getting into the red). It only cools when travelling at high speed when ambient temperature is cool. Subsequently, the transmission fluid is also hot (again, 200+ degrees).
I'm not sure whether there is an issue with the water pump that was replaced, or could a thermostat with the wrong setpoint have been installed? The car is still under warranty (barely) and would like to have a better guess as to what the problem may be. If there are any procedure checks I can do to narrow it down as well, I'd be more than happy to try.
Thanks for your help!
Sep 3, 2019 at 7:27 AM
(Merged)
