The reason the remote start will not work is because the check engine light is on. The p0411 is Secondary Air Injection (AIR) System Incorrect Air Flow Detected.I've done alot of these. Seen alot of water in the air injection shut off valve, it causes rust inside the valve and it wont open or close. If you fix the check engine light and clear the code the remote start will work.
SPONSORED LINKS
Sunday, January 27th, 2008 AT 5:32 PM
