2006 Pontiac Grand Prix code
2006 PONTIAC GRAND PRIX
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBKATLISA
Our car has a insuffiant air flow code which I cant figure out what it is. I have changed the filter, the air blower seems find and I dont know if there is a another place to check. Please help, we need this car to take our 3 year old son who needs a kidney transplant back and fourth to the hospital and we cant get it inspected untill the code is gone.
Apr 10, 2010 at 7:06 AM
BMRFIXIT
  • 19,053 POSTS
what do you have for codes ??
what do you have for engine size ?
Apr 12, 2010 at 11:59 AM
ROBKATLISA
the codes for my car is po411 insufficent air flow. the engine size 6 clyinder base model.
I took apart the air pump and there was no moisture in it. The air pump does run so I'm not sure what else it could be. If you have any advice on what to do please let me know I'm at a complete loss.
Thank you and god bless,
Rob
Apr 12, 2010 at 1:12 PM
BMRFIXIT
  • 19,053 POSTS
Check fuses if fuse is blown suspect bad air pump
Very common
Fuse located under hood by right strut
reset and clean codes
Apr 13, 2010 at 10:28 AM
