Hesitation
2004 PONTIAC GRAND PRIX
156,000 MILES • 6 CYL • 2WD • AUTOMATIC
YETI64
My car will hesitate when accelerating on a hill or under a slight load. Happens from a stop or at speed. On ramp to highways with a slight incline will cause the hesitation. Recently had tuneup, oil change and changed fuel filter. Used injector cleaner three times.
With no difference.
Apr 10, 2008 at 6:00 AM
THE KIDD
This sounds like you have a problem with the MAF sensor which if it gets off a liltte will not trigger a check engine light.
Here are tow guides to help you get the problem fixed:
https://www.2carpros.com/articles/engine-hesitates
and
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Cheers
May 5, 2008 at 11:20 AM
CADDYCANFIELD
This thread is spot on. The MAF fixed my car.
May 6, 2018 at 5:40 PM
