HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Prix
Engine
Symptoms
Low Power
2002 Pontiac Grand Prix loss of power engine light on
DAVE GALLOWAY
MEMBER
2002 PONTIAC GRAND PRIX
6 CYL
FWD
AUTOMATIC
157,000 MILES
Could cataletic converter cause loss of power, were is the fuel filter?
Tuesday, June 23rd, 2009 AT 2:26 PM
MMPRINCE4000
MECHANIC
A clogged or partially clogged filter can cause an engine to run rough, hesitate and even prevent it from running.
Filter is generally in rear, follow lines from tank look for this:
SPONSORED LINKS
Wednesday, June 24th, 2009 AT 9:18 AM
Please
login
or
register
to post a reply.
Related Engine Low Power Content
Car Has No Power And Seems To Run Lean, Possible...
Fuel Pressure Never Drops Below 50lbs, No Restriction In Exhaust System Although Seems White Inside As If Its Running Lean. Compression...
Asked by
v84u2nv
2002
PONTIAC GRAND PRIX
VIDEO
Fix an Engine with Low Power!
Instructional repair video
GUIDE
Symptoms of Low Engine Power
The power your car's engine is producing is important. When you step on the gas you need your car to accelerate, mainly to keep you out of trouble when getting onto the...
2002 Pontiac Grand Prix Loss Of Power
My Grand Prix Has A Loss Of Power When It Accelerates And Does Not Want To Change Gears Unless I Let Off The Accelerator. When It Doesn't...
Asked by
brtla
1 ANSWER
2002
PONTIAC GRAND PRIX
Have A 3800, Suspect Converter Is Problem. Have All Ready Changed Fuel Filter, Checked Air Filter, Bit Dirty But Not Enough To Cause The...
Asked by
draziw_one
2002
PONTIAC GRAND PRIX
2002 Pontiac Grand Prix Car Will Not Accelerate, No...
Have A 2002 Bonneville And A 2002 Grand Prix Gt. The Mil On The Gp Appears Not To Be Working. The Engine Is Running Poorly But The Check...
Asked by
stevejobe
1 ANSWER
2002
PONTIAC GRAND PRIX
02 Pontiac Grand Prix Gt Running Sluggish...help !
[b] :cry:can Anyone Tell Me What Can Be Causing My Pontiac Grand Prix To Be Running Sluggish? When The Gas Pedal Is Pressed The Car Jerks...
Asked by
jason7853081
1 ANSWER
2002
PONTIAC GRAND PRIX
VIEW MORE
SPONSORED LINKS
Catalytic Converter Replacement
Online car repair manuals
