2002 Pontiac Grand Prix Acceleration
NRDAVIS9013
  • 2002 PONTIAC GRAND PRIX
  • 6 CYL
  • 100,000 MILES
At 30 mile/hr and 70 mile/hr it slows down and when I push the gas it does not accelerate and it feels like it is having hickups.
Friday, February 12th, 2010 AT 7:33 PM
Inspect and test all the following listed below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Cap and rotor
Note:If it doesn't apply disregard.
Saturday, February 13th, 2010 AT 3:11 AM
