2001 Pontiac Grand Prix Stumped...please help!!!
87,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIGUEL123
  • 5 POSTS
I have been hearing a rumbling (buzzing maybe) noise that gets louder as the car accelerates and continues the entire time the car is moving. I know it can't be in the engine since I can put the car in neutral and the noise continues as the car coasts. The noise is louder than the radio now!!! I noticed when I turn to the right it goes away, but to the left it gets worse, so I replaced the axle/cv joint assembly and the hub assembly on the left side. Now the noise is still there and I also can hear rubbing when I turn. Please somebody help me!!! It's driving me mad!
Feb 25, 2009 at 3:24 AM
MMPRINCE4000
  • 8,548 POSTS
Raise car put on stands, grasp tire and push/pull both horizontally and vertically, you are looking for any movement, which would indicate a bearing, ball joint, tie rod, or bushing problem. Do this on both wheels.
Also inspect the CV boots on the other axle, look for rips/tears in the boot (inner and outer) and any lubricant leaking from boots.
Also inspect the brakes, make sure calipers bolts are tight as well as bracket is tight.
Feb 25, 2009 at 11:52 PM
MIGUEL123
  • 5 POSTS
Thanks for your response! I put the car on jacks and there is no movement in the wheel on either side. the brake calipers seemed fine as well as the cv joints on the side I didn't replace. (right side) The tie rods seem to be very tight with no play in them. I just don't know what else it could possibly be! Any more ideas?
Feb 26, 2009 at 7:58 AM
MIGUEL123
  • 5 POSTS
I should also tell you that I checked all this after fixing the rubbing problem. The axle I installed wasn't tightened down as far as it could go. So that's no longer a problem, but the buzzing noise I noticed starts around 30 mph and gets very loud as I near 60 mph.
Feb 26, 2009 at 8:01 AM
MMPRINCE4000
  • 8,548 POSTS
Make sure the fluid level in trans is full. Check the motor mounts, but it sure sounds like a bearing.
Try moving front tires to rear, see if noise moves with them.
Feb 27, 2009 at 12:19 AM
MIGUEL123
  • 5 POSTS
I have been swamped at work so I haven't got back to it yet. But I will check on all this, except the transmission fluid since I always make sure that's up to level anyways. I will let you know. What woul d I check on the motor mounts?
Mar 4, 2009 at 7:08 AM
