2001 Pontiac Grand Prix--Problems Starting(Please Help)!
MISSPRICE
  • 2001 PONTIAC GRAND PRIX
  • 6 CYL
  • 156,000 MILES
Got a 01 Pontiac Grand Prix. Sat for 6 months. Jumped the car, noticed it was over heating. Fixed coolant leak. Car won't start now. Replaced battery, no codes stored in computer. Car has spark and decent fuel pressure. Please help!
Thursday, March 5th, 2009 AT 10:58 AM
MMPRINCE4000
  • 8,548 POSTS
You need spark, fuel and compression for car to run.
Spark should be blue snapping spark, fuel pressure should at least 40psi.
Check compression.
Having sat for a long period I would change the plugs or at least inspect them.
Friday, March 6th, 2009 AT 8:24 AM
MISSPRICE
Car was running then it died. Car has spark. Already changed spark plugs and wires, got a spark. Fuel is at half tank but fuel smells funny. Kinda smell like a paint thinner.
Someone told me to check the crank sensor or cam sensor. Could that be the problem?
Friday, March 6th, 2009 AT 11:59 AM
MMPRINCE4000
  • 8,548 POSTS
I would drain the gas tank, change filter and add a fuel stabilizer or Seafoam.
If it does not have the blue snapping spark, it is considered no spark.
A car that sat for 6 mo. Without any fuel stabilizer, would cause varnish to build up in fuel system, including injectors.
Sunday, March 8th, 2009 AT 6:08 AM
PITURA
Check the fuel pump resistor. $30 part can cause starting or running problems if it fails.
GM Part # 88951182
Sunday, March 8th, 2009 AT 8:53 AM
