HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Prix
Electrical
Ignition Switch
2001 Pontiac Grand Prix IGNITION SWITCH
SADIEBEAR1
MEMBER
2001 PONTIAC GRAND PRIX
6 CYL
2WD
AUTOMATIC
70,000 MILES
IGNITION SWITCH WORKS FINE MOST OF THE TIME BUT OCCASIONALY WILL NOT GO TO OFF, LOCK POSITION, WHAT COULD BE POSSIBLE PROBLEM?
Thursday, April 9th, 2009 AT 9:04 AM
BLUELIGHTNIN6
MECHANIC
There are several things that may cause this intermittent problem. You can read about this common issue at the following link..
https://www.2carpros.com/first_things/why_wont_my_ignition_switch_turn.htm
You may have to replace the ignition lock cylinder to solve this issue permanently, however I suggest first trying a new key.
Thanks for using 2CarPros.com!
Thursday, April 9th, 2009 AT 1:25 PM
Please
login
or
register
to post a reply.
Related Ignition Switch Content
What Is In Between Ignition Switch And Starter
Car Would Not Start Testecd The Starter With Screwdriver From B Terminal To S Terminal It Will Crank Over. Then Tested The Voltage To The S...
Asked by
diddums
2 IMAGES
2006
PONTIAC GRAND PRIX
The Ignition Switch
The Ignition Switch Locks In Acc Only
Asked by
ken49
1 IMAGE
2003
PONTIAC GRAND PRIX
In The Back Of The Engine Kind Of By The Alternator...
In The Back Of The Engine Kind Of By The Alternator There Are Two Orange Wires On A Connector One With A Black Line Down The Middle. And I...
Asked by
Nate21thielen
2001
PONTIAC GRAND PRIX
Fuse Panel Find The Radio Fuse ?
I'm Trying To Find The Radio Fuse Inside The Fuse Box?
Asked by
MyTaurus77
28 IMAGES
2007
PONTIAC GRAND PRIX
What Does Charging System Failure Mean? Alternator...
Yesterday I Went To My 04 Pontiac Grand Prix Gtp And When I Started It Took A Minute Start And All The Lights In The Car Went Crazy. My...
Asked by
kbest92
1 IMAGE
2004
PONTIAC GRAND PRIX
VIEW MORE
Battery Replacement Ford
Battery Replacement
