2001 Pontiac Grand Prix Can i fix this on my own
2001 PONTIAC GRAND PRIX
166,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAYLUCKY25
My car shakes horrible when i press on the gas and then when i let off, it is a little better but still shakes. Ive been told before i need new motor mounts. Can i fix this myslef. A friend told me i could weld in place of broken mount so my engine wont shake anymore. Is this true because my boyfriend is a welder?
Nov 12, 2008 at 6:28 AM
  • 31,937 POSTS
Hi there,
If this problem is a broken engine mount, replace it with a new one, if you try to weld a solid mount up it will be so bad that it will shake out your fillings, fix it correctly.
mark (mhpautos)
Nov 12, 2008 at 7:36 AM
JAYLUCKY25
isn't that expensive though, i was looking for a cheap fix... how safe is it to drive with it broken?? ive been driving on it broken for prolly 4 months now.
Nov 12, 2008 at 7:40 AM
  • 31,937 POSTS
The extra vibration will damage other mounts and fittings, it's up to you, but i would fix it now or pay more later when something else fails because of the vibration, just get it inspected first to make sure that this is your problem in the first place.
mark (mhpautos)
Nov 12, 2008 at 7:48 AM
