2001 Pontiac Grand Prix
MARKC3503
  • 2001 PONTIAC GRAND PRIX
when I crank my car it idles high at fist then will idle down. When Im driving it the rpms will not fall below 1500. When I shift into park or nuetral it will rev up to 2000 rpms. I have replaced the idle air control valve and have checked all the visible vaccum hoses. I need another opinion on what it might be thanks
Wednesday, February 10th, 2010 AT 1:47 PM
TOOOMANYTOYS
  • 513 POSTS
Is the check engine light on? Also check the throttle plate it should close tightly to throttle body.
Wednesday, February 10th, 2010 AT 1:50 PM
MARKC3503
Yeah the check engine light is on but its the o2 sensor
Thursday, February 11th, 2010 AT 10:31 AM
TOOOMANYTOYS
  • 513 POSTS
Try using a spray bottle of water spray around the intake manifold and throttle body. If rpms change you may have a vacuum leak.
Thursday, February 11th, 2010 AT 1:26 PM
