First use a test light to verify it is the switch. The brake switch also works the shift lock. Test for power at the dark green/white wire on the brake switch with brake pedal pushed, if no power then it is the switch, if power you need to disassemble the console to gain access to the solenoid and test for power there
SPONSORED LINKS
Friday, May 23rd, 2008 AT 8:02 AM
