2001 Pontiac Grand Prix Factory security system
ALEXP1214
  • 2001 PONTIAC GRAND PRIX
  • 6 CYL
  • 90,000 MILES
My car starts up okay, but after about 3 seconds it shuts itself off and the 'security' light blinks on the dashboard. I read from my manual that my key has a transmitter, so I tried all of the keys I have to see if maybe it was just that key, but it still turned off. I read that disconnecting the battery will allow you to drive the car but the light still blinks. I have not tried anything else beyond checking the key. Any help you can provide is greatly appreciated. Thank you.
Friday, January 16th, 2009 AT 7:24 PM
BRIAN 1
  • 1,030 POSTS
Have it scanned for any security codes and post back with the code and I will advise from there.
Friday, January 16th, 2009 AT 9:48 PM
ALEXP1214
I had a mechanic hook up computer to car. I did not get code, but he said that the car's security system is shutting car off, and that the security system itself would have to be 'reset' and that it could only be done at a gm dealership. I did try disconnecting the battery for an hour but issue continued after I reconnected. Any ideas? If the code itself is still necessary, I will see what I can do about getting specifics. Thanks.
Sunday, January 18th, 2009 AT 9:41 AM
BRIAN 1
  • 1,030 POSTS
If the security light is flashing there is a code. Most shops dont have the equipment to retrieve these codes, only the dealer can. There is a problem in the passlock system. Disconnecting the battery on new or newer cars does nothing. Without a code it would just be a guess. Post back with any other questions.
Sunday, January 18th, 2009 AT 10:00 AM
ALEXP1214
Okay well thanks for your advice. I will try to get the code info and post it, but may take a few days. Thanks again.
Sunday, January 18th, 2009 AT 10:24 AM
