2000 Pontiac Grand Prix Probably a security electrical issu
OZWORKS
MEMBER
2000 PONTIAC GRAND PRIX
6 CYL
2WD
AUTOMATIC
130,000 MILES
We have a 2000 Pontiac grand prix, it starts, then shuts off by itself right away. Any suggestions that may help us? Thank you…
Monday, June 30th, 2008 AT 8:15 AM
MERLIN2021
MECHANIC
Have you done a relearn on the pass-key?
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
SPONSORED LINKS
Monday, June 30th, 2008 AT 8:19 AM
OZWORKS
MEMBER
What if this does not work? Can I disable this feature? Thank you
