2000 Pontiac Grand Prix heater blower
170,300 MILES • 6 CYL • 2WD • AUTOMATIC
AMBOSH98
how to change heater blower
Dec 17, 2008 at 8:37 AM
  • 110,246 POSTS
Hi:
First, are you sure it's the blower motor and not the resister or switch?
If you are sure, I recommend purchasing a repair manual for your car. It's a very involved job that will require partial removal of the dashboard. A manual will provide step by step instructions and pictures to identify parts.
Let me know if you have any questions.
Dec 17, 2008 at 2:04 PM
AMBOSH98
no t sure if it is the blower or nor we have been having problems with it for a couple of weeks now and some times it works and some time it dont we can be driving down the road and it just up and quit and not worrk for days but then after a few days it will work
Dec 18, 2008 at 1:29 AM
  • 110,246 POSTS
HI:
When the fan stops working, you need to check if power is getting to the motor. If it's getting power, then replace the motor, but if it isn't, the problem is somewhere else.
Keep in mind, when a fan motor goes bad, it either draws too many amps causing the resister to burn-up, or it just stops working. That's why I don't want you to replace it until we are sure where the problem is.
Let me know what you find.
Dec 18, 2008 at 2:34 AM
FISHCJS
Just replaced the blower in one. u do not need to pull the dash but its a challenge....my back still hurts!
Jan 19, 2009 at 7:30 AM
