2000 Pontiac Grand Prix electical
2000 PONTIAC GRAND PRIX
BEAUCOS
2000 Pontiac Grand Prix 6 cyl Front Wheel Drive 120000 miles
so here is my problem, i have a 2000 pontiac grand prix, and the radio lights dont work the dtrl dont work the abs light is stuck on the heater olny works on five, and trac control is stuck on too. so i was reading alot on the post and it said it sounds like the ignition switch so i replaced it today and did not solve any of the problems. so what should i do now?
Feb 28, 2010 at 12:02 PM
JDL
  • 16,098 POSTS
Hi, if the blower only works on high, maybe a problem with resistor? My info on radio illumination, says, come from headlamp switch. I'm not saying, replace the switch, I'd check the radio illumination circuit for voltage. Not sure about the trac lite?
Mar 2, 2010 at 4:33 AM
SMAX23
  • 12 POSTS
Check your BCM..it's located over on the driver side above your emergency break pedal. Did you get the correct ignition switch for your car..as in do you have a floor shifter or column shifter..that makes a difference as well. good luck :)
Apr 4, 2010 at 7:04 PM
