2000 Pontiac Grand Prix brake lights
ROSSUM76
  • 2000 PONTIAC GRAND PRIX
  • 6 CYL
  • 70,000 MILES
All my brake lights aren't working. The middle one works but the two on the side do not. I checked all the bulbs, none blown. The blinkers, running, and reverse lights all turn on. I also checked all the fuses, none blown. What else to check?
Tuesday, June 23rd, 2009 AT 5:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty brake lamp switch. Switch is attached to your brake pedal arm, under driver side dash. It controls the two main brake lamps while a separate relay controls the high-mount (third) brake lamp.
Tuesday, June 23rd, 2009 AT 5:40 PM
