If engine has a high idle the intake gaskets are leaking, if idle is OK, then most likely the convertor is clogged or partially clogged.
Start by checking spark and fuel pressure with mechanical gauge, if OK, then convertor is the likely culprit.
SPONSORED LINKS
Saturday, September 19th, 2009 AT 7:34 AM
