1999 Pontiac Grand Prix Grand Prix with no heat
JOEELL
  • 1999 PONTIAC GRAND PRIX
  • 6 CYL
  • 96,000 MILES
My 1999 Grand Prix has no heat. The defroster has heat and the blower is blowing only cold air. Last year the blower didn't work and they replaced the ignition switch. Also in the past year they've replaced the intake manifold gasket, thermostat and water pump after some overheating issues. I was hoping that something was just frozen as it's been under freezing here for days but I went out for a long ride yesterday and that didn't help.
Sunday, January 4th, 2009 AT 8:14 AM
2CARPRO JACK
  • 11,533 POSTS
Warm the car up and check to seee if the heater hoses are getting hot, if not you may have a flow problem with the heater core. If they are hot, check the blend door under the dash to be sure it is moving from hot to cold.
Sunday, January 4th, 2009 AT 8:47 AM
