I have a 1999 Pontiac Grand Prix GTP. The fuel pump has been shutting down intermittently. Found the voltage at the pump was dropping and eventually shutting down after many hours of monitoring. I have now replaced the fuel pump resistor with and new GM part and relocated. Car has not stalled as of this time, but the pump voltage still seems low. 10- 11 volts cold and 9-10 volts hot. Drops as time progresses and the resistor heats up - the new resistor still gets very warm - almost hot. Can the pump be pulling too many amps and causing the resistor to heat up and eventually shut the pump down?
SPONSORED LINKS
Tuesday, December 15th, 2009 AT 9:47 PM
