coolant leak
255,000 MILES • 6 CYL • FWD • AUTOMATIC
JYD314
My car is consuming alot of antifreeze, adding coolant several times a month. My temp gauge is way above normal and the low coolant light comes on even when its coolant in the vehicle. Its not leaking when sitting still and when the heat is on the guage is within normal range.
I had the thermostat replaced and coolant switch replaced.
Sep 9, 2010 at 12:09 PM
  • 110,248 POSTS
Is there any evidence of coolant leaking under the vehicle? Have you checked to make sure the engine oil and trans fluid are not contaminated with coolant? Is there white smoke that comes from the exhaust of the vehicle?
Sep 10, 2010 at 6:42 AM
JYD314
There is no coolant leak underneath car. I checked the oil and tranny fluid and didn't notice anything abnormal, fluids are of normal color. No smoke coming from either pipe.
It does look as if the fluid flowing into resevoir from radiator is more water than coolant. (or could just be me).
The gauge hand used to read normal levels before I had t-stat, thermo switch and resevoir replaced.
Sep 10, 2010 at 10:44 AM
  • 110,248 POSTS
I wonder if the t-stat was put in upside down. It this didn't happen until the work was done, that is possible.
Sep 10, 2010 at 5:29 PM
JYD314
I just noticed today that after I run the heater on low to keep gauge low, there is a drip comming from underneath passenger side of car after its parked and turned off. No coolant, just water. I"ll check to see if t stat is put n wrong.
Sep 11, 2010 at 8:51 AM
  • 110,248 POSTS
When you run the heater, is the AC turning on? Do you have it on defroster?
Let me know what you find.
Sep 13, 2010 at 12:34 AM
