1998 Pontiac Grand Prix blower motor fan
PHILCAR
  • 1998 PONTIAC GRAND PRIX
Heater problem
1998 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
the blower motor only works on highest speed. I here that this is probably the resisitor but I cannot seam to find it. Can you help?
Thursday, January 22nd, 2009 AT 10:44 AM
JDL
  • 16,098 POSTS
Hello, under the dash, passenger side, you will probably have to remove the lower dash insulator. The blower motor plugs into the resistor assembly. Have you checked the fuses for the lower speeds, I forgot to look.
20 amp, hvac control fuse, also check that the circuit is hot, where the fuse plugs-in.
Thursday, January 22nd, 2009 AT 11:17 AM
