1997 Pontiac Grand Prix
DM_KILLORA
  • 1997 PONTIAC GRAND PRIX
  • 6 CYL
  • 124,000 MILES
The engine starts and idles fine when you accelerate
it dies
Friday, April 10th, 2009 AT 9:04 AM
MMPRINCE4000
  • 8,548 POSTS
You will have to check fuel pressure with a mechanical gauge, pressure should hold for a few minutes after pump is off and when you "blip" throttle, pressure should go up a few psi.
Pressure should be 40-45psi, if below 25psi, it may idle but will not run under load.
Friday, April 10th, 2009 AT 11:12 AM
