HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Prix
Electrical
Battery
1996 Pontiac Grand Prix Car Trouble
SANDREKALESTER
MEMBER
1996 PONTIAC GRAND PRIX
4 CYL
4WD
AUTOMATIC
168,000 MILES
Why does my car keep stopping while I am driving? It isnt runnugn hot. It isnt the battery. What else could it be?
Tuesday, September 14th, 2010 AT 10:03 AM
ERNEST CLARK
MECHANIC
Are you getting a check engine light? If so, then start by having your computer scanned. Then get back with me with the codes.
What you're experiencing is either a fuel starvation problem, a sever vacuum leak or a failing sensor.
Wednesday, September 15th, 2010 AT 6:14 AM
Please
login
or
register
to post a reply.
Related Battery Content
1996 Pontiac Grand Prix Alternator
1996 Pontiac Grand Prix 6 Cyl Front Wheel Drive We Are Having A Problem Getting The Longer Bolt Out Of The Alternator To Pull It Out...
Asked by
arasnosreip19
1 ANSWER
1996
PONTIAC GRAND PRIX
VIDEO
How to Charge an Automotive Battery
Instructional repair video
GUIDE
Battery Connected Backwards
It is easy to connect a battery backwards and it happens more than you think, so don't feel bad if you are here for that reason. Your car has safeguards built in to help...
Fuse Panel Find The Radio Fuse ?
I'm Trying To Find The Radio Fuse Inside The Fuse Box?
Asked by
MyTaurus77
28 IMAGES
2007
PONTIAC GRAND PRIX
What Is In Between Ignition Switch And Starter
Car Would Not Start Testecd The Starter With Screwdriver From B Terminal To S Terminal It Will Crank Over. Then Tested The Voltage To The S...
Asked by
diddums
2 IMAGES
2006
PONTIAC GRAND PRIX
What Does Charging System Failure Mean? Alternator...
Yesterday I Went To My 04 Pontiac Grand Prix Gtp And When I Started It Took A Minute Start And All The Lights In The Car Went Crazy. My...
Asked by
kbest92
1 IMAGE
2004
PONTIAC GRAND PRIX
The Ignition Switch
The Ignition Switch Locks In Acc Only
Asked by
ken49
1 IMAGE
2003
PONTIAC GRAND PRIX
VIEW MORE
Battery Replacement
How to Replace Battery Toyota Tacoma
