Remove the battery connections and clean them, both power and ground. Remove starter and have it bench tested at most autoparts stores for free.
Starter grounds to block so make sure starter is grounded properly.
Have charging system tested at most autoparts stores for free.
If problem persists, then relay is bad or ign. Switch.
SPONSORED LINKS
Monday, March 16th, 2009 AT 7:46 AM
