1995 Pontiac Grand Prix Engine goes dead while driving
STARLITE9080
  • 1995 PONTIAC GRAND PRIX
Engine Mechanical problem
1995 Pontiac Grand Prix 6 cyl All Wheel Drive Automatic
Two times recently, my Pontiac Grand Prix engine has gone dead while driving. The firs time, I had only driven about a block and half and the second time I had driven approximately 20 miles.
Also, I had a problem with the car "clicking" when I would tyr to crank it. This was sporadic. At times it would crank up immediately and other times it would click several times then crank. A local repait shop replaced the starter but the car would still click occassionally. One time, after the starter was replaced, the engine immediately begun to crank but during the cranking process, I could hear a rapid clicking, such as you hear when there is a battery of battery connection problem.
Last Friday, the engine would not turn over or make any noise whatsoever when I tried to crank it. I had to have it jumped off with a "jump box" in order to get it to start. My husband replaced the battery (but not the battery cables) and it now cranks fine, but went dead this morning while I was driving.
The car cranks back up with no problem after going dead.
I appreciate any advice you can offer.
Monday, February 2nd, 2009 AT 7:59 AM
JDL
  • 16,098 POSTS
Were the dash lites on, when the vehicle went dead? Do you have a theft system? Can you check for codes?
Are all the battery cables/ wires clean and tight on both ends?
Monday, February 2nd, 2009 AT 12:45 PM
STARLITE9080
The dash lites were not on. The lites and radio went off when the engine died. No thefy system. I do not know how to check for codes. The battery cables are clean and tight on the battery end but I don't know about the other end
uote="jdl123"]Were the dash lites on, when the vehicle went dead? Do you have a theft system? Can you check for codes?
Are all the battery cables/ wires clean and tight on both ends?[/Quote]
Monday, February 2nd, 2009 AT 1:37 PM
JDL
  • 16,098 POSTS
Right now it sounds like an intermittent electrical connection, somewhere.
I'd make sure the battery cables/wires are all clean and tight on both ends. You may have a problem with the ignition switch or feed.
Monday, February 2nd, 2009 AT 2:14 PM
