How can I get into my 1995 Pontiac Grand Prix if both door handles are broken? I have tried everything that I can think of.
Sunday, January 10th, 2010 AT 12:48 PM
MMPRINCE4000
MECHANIC
You could have a locksmith get into car, or use pliers and break the plastic handle (you will have to replace it) grab door rod (use needle nose pliers) and pull to open.
You can try local autoparts stores for replacement door handles.
SPONSORED LINKS
Monday, January 11th, 2010 AT 9:15 AM
TMINNEAR
MEMBER
Try going in from the trunk I had same problem I have a small door in trungk leading to cab I took a broom handle and taped a wire coat hanger and did a little fishing I got ahold of the front driver side inside handle and had someone pull on the door after I got the latch popped if this help good fishing
