1994 Pontiac Grand Prix steering
BANDO101
  • 1994 PONTIAC GRAND PRIX
Steering problem
1994 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
the car i'm driving is 94 grand prix, my probablem is when driving either slow or hyway speed when I go around a bend (not corner) to the right the car shimmers and the steering wheel vibrates but to the left it is solid and no vibration, i'v already changed the outer tierod ends, my only guess could be of these three things; the inner tierods, ball joints or rack and pin steering gear which the mounts seem to be solid. Any ideas would be helpful to narrow this down would be great.
Thursday, November 26th, 2009 AT 2:25 PM
MMPRINCE4000
  • 8,548 POSTS
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Also when you change outer tie rods, you need to get the alignment "toe" checked.
Friday, November 27th, 2009 AT 6:09 AM
